PRI / SRST incoming calls get dial tone
May 10th, 2007
I am running CCM 4.1.3 with SRST. In fallback mode, when calling INTO the PRI, I get a secondary dial tone. If I then dial an extension, it will ring the phone. What am I missing to allow a normal call from the outside to reach the intended DID? Thanks
Overall Rating: 4 (1 ratings)
Brandon Buffin Thu, 05/10/2007 - 05:06
  • Purple, 4500 points or more
Under your incoming dial peer, you need the command "direct-inward-dial".
Hope this helps. If so, please rate the post.
Brandon
hauchinango Thu, 05/10/2007 - 05:14
Ball,
I have the following dial peer and problem persists:
dial-peer voice 7777 pots
preference 1
destination-pattern 9T
progress_ind setup enable 3
incoming called-number .
fax rate disable
direct-inward-dial
astinus Thu, 05/10/2007 - 05:16
  • Bronze, 100 points or more
Believe you need to indicate the port under here as well. IE if 1/0 is your PRI, you need the command
port 1/0:23
under this dial peer.
Hope this helps.
Jim
hauchinango Thu, 05/10/2007 - 05:54
JIm,
Yes, I omited the port. I put the port in and also an num-exp statement, and incoming works. Thansk to all
Brandon Buffin Thu, 05/10/2007 - 05:17
If you do "debug voip dialpeer" and make an incoming call, do you see that the call hits the proper dial peer?
Brandon
