1751 booting problem
May 10th, 2007
I have 1751 router which is giving problem at the instance when I power ON it. below log message appears at console and not even coming in ROM monitor.
System Bootstrap, Version 12.2(1r)XE1, RELEASE SOFTWARE (fc1)
TAC Support: http://www.cisco.com/cgi-bin/ibld/view.pl?i=support
Copyright (c) 2001 by cisco Systems, Inc.
Kindly suggest to overcome this problem.
Hardik..
hardik_tankaria Thu, 05/10/2007 - 05:24
I missed to point one more thing.
While doing Clt Break to enter into ROM Monitor below error displays..
*** Software Emulation Exception ***
PC = 0x0, Vector = 0x1000, SP = 0xff002500
Need your assistance.
Hardik..
hardik_tankaria Sun, 05/13/2007 - 23:11
Hi Satish,
Thanks for url; the problem is that I tried to get into ROM monitor and wanted to upload some upgraded IOS. But even ROM is not accessible.
Is there any other way I can get into ROM?
Hardik..
nikolay-shopik Mon, 05/14/2007 - 02:24
As I told you before usually this is hardware fault especially in capacitor - have few cases when capacitor just swell up and need to be replaced.
If you know ccna course you should know if ROMMON can't be accessed that because hardware don't pass POST tests.
