Max cable length for G.703
May 10th, 2007
Hi, I've got a circuit that is terminated using BNC connectors in a comms cabinet. The router is going to be installed about 15 meteres away.
What would be the best cable to use for this? I'm thinking I could use a CAB-E1-BNC, a 15m patch lead and a coupler to join them together. Would this be viable? or is there a better option?
Many Thanks in advance, Dom
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Thu, 05/10/2007 - 07:06
yes, the best would be coax extenders to the cable ends. Your are within the max length by a factor of like 10.
d-fillmore Fri, 05/11/2007 - 00:14
Hi - Thanks for your response. I think I got the cable part number wrong. There is a Cisco part which is a BNC to RJ45 convertor. I want to connect that end to the cirucit termination points, then join the other end to a long patch lead using a coupler, then plug the patch lead into the WIC-1MFT-E1
