IP block support on L3 4507 switch
May 10th, 2007
it would be kind of you, if any on can say me how many IP blocks is been supported by 4507 L3 switch. note all the ips are public.
eg: i have 20.1.2.x to 20.1.15.x
and 20.3.x.x and 202.x.x.x series of IP's which i would like to integrate in vlan.
is it posible for me to use CIDR for default route and wht would be my management valan ip and is that management vlan accessable from remote.
Gopi
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 05/10/2007 - 06:46
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Gopi
Not sure what you mean by how many ip blocks. The 4500 will support
1) 32000 or 128000 routes depending on the suprevisor you have. ( Sup IV, V, V-10GE support 128000 other 32000).
2) 4500 will support up to 4096 vlans.
So with this information you should be able to work out if this is enough for what you need.
Yes you can use CIDR but this also depends on the routing protocol you choose to use.
You managment vlan can be any vlan you want with any IP address range. Best practice is to use something other than vlan 1.
Jon
sgopi1977 Thu, 05/10/2007 - 11:09
Hi Jon,
Thanks you for the explanation,
4507R - Sup V-10GE
Routing Protocol - OSPF
Related to IP blocks.
Eg: i would be creating 15 Vlans within 4507R switch which is going to be directly connected to my Production Servers.
A Group of servers say around 8 would be in vlan10 with ip's 20.1.2.x to 20.1.2.xx
Vlan20 with ip's 20.2.1.x to 20.2.1.xx
Vlan30 with ip's 202.15.2.x 202.15.2.xx
--->>>> my question is ?
like this i would be having different IP-blocks for each VLAN,
so is it possible for inter-vlan communication and all severs communicate outside at the same time.
kindly take a look at the n/w diagram. let me know.
gopi
Jon Marshall Thu, 05/10/2007 - 11:21
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Gopi
You should be fine with this setup. Yes inter-vlan communcation will work fine as long as you create Layer 3 SVI's (Switched Virtual Interfaces) on your 4500 switches.
Yes they can all communicate at the same time if i understand correctly.
Hope this answers your question
Jon
sgopi1977 Thu, 05/10/2007 - 14:03
Hi Jon,
Thank you very much,
you have solved my query about it, it had helped me a lot in discussing with my HOD.
Thanks & Regards,
Gopi
