gogasca Thu, 05/10/2007 - 07:33
  • Green, 3000 points or more
Hi Christian...
Normally internally you achieve this with a Translation Pattern XXXX with called party transform mask for the Operator number...
I remember once I tested it externally, just make sure that CSS of GW can reach the TP partition and TP CSS can reach Operator number.
christian.testa Thu, 05/10/2007 - 08:05
Hi H,
Problem is I'm already translating the delivered telco digits, 67XXXX, to the internal phone range of 81XXXX; so I can't have another translation applied to the range...?
Christian
