Unity MWI not working for some users
jsailers
Unity 4.0(5), CCM 4.1(3), Exchange Integration, Unified Messaging.
We are having a problem intermittently with MWI. We noticed the problem yesterday.
Problem: Some users noticed that they had messages, but their light was not on. To verify, I logged into their mailbox and marked a voice message as unread and watched the Port Status Monitor for the MWI to go out... Nothing.
Supporting info: Other users in the same mailstore, same Active Directory OU, and had the same permissions were working fine. I had at least 3 users experiencing this problem.
Solution: Restarting the AVMsgStoreMonitor service ultimately fixed the problem.
Question: I am trying to understand WHY this happened, and how can I monitor for this if it happens again.
5 Replies 5
Zin.Karzazi
Level 5
Level 5
Posting some Eventviewer Errors would be helpful.
There are not event logs directly related to this problem. However there are a few errors and warnings over the last few days that could be indirectly related:
Event Type: Error
Event Source: CiscoUnity_AvRdbSvr
Event Category: Startup
Event ID: 21000
Date: 5/7/2007
Time: 4:08:22 PM
User: N/A
Computer: JC-IPT-UM1A
Description:
Failed connecting to underlying database using: provider=SQLOLEDB;driver={SQL Server};Data Source=JC-IPT-UM1A;Initial Catalog=UnityDb;uid=Administrator;pwd=
For more information, click: http://www.CiscoUnitySupport.com/find.php
Event Type: Error
Event ID: 21000
Date: 5/7/2007
Time: 4:08:22 PM
User: N/A
Description:
Failed connecting to underlying database using: provider=SQLOLEDB;driver={SQL Server};Data Source=JC-IPT-UM1A;Initial Catalog=UnityDb;Integrated Security=SSPI: 8000ffff
Event Type: Warning
Event Source: CiscoUnity_DirChangeWriter
Event Category: Warning
Event ID: 1050
Date: 5/7/2007
Time: 4:12:21 PM
User: N/A
Description:
The allsubscribers directory object was deleted. The corresponding Cisco Unity account is undeletable.
Some functionality will be unavailable, and Cisco Unity may fail to function properly until the directory object is restored.
To restore the directory object, run the Message Store Configuration Wizard with the sync flag: "C:\CommServer\ConfigurationSetup\setup.exe" /sync
Although not related to MWI, I recently seen the same error message (event ID 21000) on our primary Unity server. Consequently our Unity failed over to the secondary Unity server.
We opened up a TAC Case and they recommended we install the latest Win 2k SP4 patches and SQL Service pack. Since we installed these patches we have not had any issues.
Here is a thread of a previous conversation on the same error message:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=Unified%20Communications%20Applications&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dd803fd
Good luck.
neesharm
was there a lan outage recently ?
Do have a failover unity configuration ?(if yes you might want to look at following bug )
http://www.cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCsb72324
Also here is a step by step guide to troubleshoot mwi
http://www.cisco.com/en/US/customer/docs/voice_ip_comm/unity/403/troubleshooting/guide/ex/TSG_0500.html
There wasn't a LAN outage that I'm aware of and we don't have failover. I appreciate your post, though.
I think I may have found the bug: http://cisco.com/cgi-bin/Support/Bugtool/onebug.pl?bugid=CSCec50802
This states that this problem can occur if the mailstore that the Unity subscribers are located on is dismounted and re-mounted. Our Exchange team confirmed that they did dismount and re-mount the store last weekend which fits into the timetable for when the problem started.
FIX: Restart the AvMsgStoreMonitor service. This is first fixed in 4.3(0.25).
Any thoughts about why the AvMsgStoreMonitor service would not recover from the mailstore being remounted?
