05-10-2007 09:03 AM - edited 03-05-2019 03:59 PM
All: this port config below, is an end user port 201 is for data, 246 is for voice. What is the command:
"switchport trunk native vlan 205" doing?
interface FastEthernet1/0/18
switchport access vlan 201
switchport mode dynamic desirable
switchport voice vlan 246
srr-queue bandwidth share 10 10 60 20
srr-queue bandwidth shape 10 0 0 0
mls qos trust device cisco-phone
mls qos trust cos
auto qos voip cisco-phone
spanning-tree portfast
Also, if a port had a config like below:
switchport access vlan 200
switchport voice vlan 245
should there be a switchport mode access command?
05-10-2007 09:06 AM
Hi Friend,
Your second config looks better
switchport access vlan x <----Data Vlan
switchport voice vlan x <---- Voice Vlan
Once you configure voice vlan command on an interface you need not configure the switch interface as trunk port as voice vlan internall forms a trunk.
Ankur
05-10-2007 09:11 AM
ankur:
what does these commands do, if switchport voice and switchport access are also configured?
05-10-2007 09:28 AM
Well the switchport trunk exncapsulation dot1q can be removed of the phone is a Cisco phone, you would require it if there is a Avaya or any other phone.
Switchport mode dynamic desirable should actually go away when you configure switch mode access, since you have access vlan configured.
Ideally speaking this command is also not required:"switchport trunk native vlan 205": In 802.1Q trunking, all VLAN packets are tagged on the trunk link, except the native VLAN. The native VLAN packets are sent untagged on the trunk link. Therefore, the native VLAN should be the same on both switches configured for trunking. This way, you can deduce to which VLAN a frame belongs when you receive a frame with no tag. By default, VLAN 1 is the native VLAN on all switches.
Hoogen
05-10-2007 09:28 AM
Hi Friend,
This command will form a trunk and will allow all vlan traffic where vlan 205 vlan traffic will pass the trunk untagged.
Ideally when you connect an ip phone and a computer to an ip phone the recommended configuration is
Ankur
