Harold Ritter Thu, 05/10/2007 - 09:39
  • Cisco Employee,
This is not supported on the 7600. The alternative is to use a FWSM.
Hope this helps,
mayambanzumba Fri, 05/11/2007 - 04:06
That is not really the answer I was hoping for, installing a FWSM is not really an alternative, what is the road map to support this on the cisco 7600?
sadasgup Tue, 05/22/2007 - 05:45
  • Cisco Employee,
Using FWSM is definitely an alternate where you dedicate an single instance of vFW to perform NAT for a particular VRF. If this is not acceptable to you, you may consider other platforms like 7200 that can deliver a solution today for this.
However, for all potential roadmap related discussion I would recommend you to directly get in touch with your account team since this forum may not be the right place to discuss such things.
Cheers,
