Advanced Mode in 4.8 Client?
May 10th, 2007
We have client 4.8 version installed and many of the installations do not allow you to select advanced mode - it is grayed out. How do we go about getting the client to show the advanced mode capabilities?
Overall Rating: 5 (1 ratings)
carenas123 Wed, 05/16/2007 - 08:44
I think you'll need to Edit the global profile "vpnclient.ini" located on "C:\Program Files\Cisco Systems\VPN Client". Open the file "vpnclient.ini", go to value "AdvancedView" and change it to "1".
wildnwitty6 Sat, 05/19/2007 - 06:22
Thank you. That is exactly what I needed to do. I also found taking the "!" from in front of the file was part of the solution as well.
