SNMP Server and Syslog
May 10th, 2007
We have all of our network equipment configured SNMP and syslog.
There is also Ciscoworks configured.
Is Cisco works considered the SNMP server?
If so, is this also where all of the traps age going?
There are a ton of traps configured and I don't see how they are all viable in Ciscoworks.
Ther are even more than this, but here is a sample:
y
snmp-server enable traps syslog
snmp-server enable traps flex-links status
snmp-server enable traps sonet
snmp-server enable traps dial
snmp-server enable traps fru-ctrl
snmp-server enable traps entity
snmp-server enable traps rsvp
snmp-server enable traps csg agent quota database
snmp-server enable traps srp
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps c6kxbar intbus-crcexcd intbus-crcrcvrd swbus
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps port-security
snmp-server enable traps mpls traffic-eng
snmp-server enable traps mpls ldp
snmp-server enable traps isakmp policy add
snmp-server enable traps isakmp policy delete
snmp-server enable traps isakmp tunnel start
snmp-server enable traps isakmp tunnel stop
snmp-server enable traps ipsec cryptomap add
snmp-server enable traps ipsec cryptomap delete
snmp-server enable traps ipsec cryptomap attach
snmp-server enable traps ipsec cryptomap detach
snmp-server enable traps ipsec tunnel start
snmp-server enable traps ipsec tunnel stop
snmp-server enable traps ipsec too-many-sas
snmp-server enable traps alarms
snmp-server enable traps vlan-mac-limit
snmp-server enable traps voice poor-qov
snmp-server enable traps mpls vpn
jreekers Thu, 05/10/2007 - 11:35
  • Cisco Employee,
Hi.
The snmp server is configured on your devices by the "snmp-server host xxx.xxx.xxx" command. Look for that, and it will indicate where the traps are being sent.
As far as the Ciscoworks server goes, DFM is one of the modules within LMS that has snmp trap handling functionality as a part of it. I'm not sure what version of LMS you're running, but here's some documentation that speaks to the functionality of DFM:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dfm206/ug/intro.htm
I hope this helps.
-Joe
wilson_1234_2 Thu, 05/10/2007 - 12:39
If we add a device to the network,can we just point it to the SNMP host?
Does the host have to be specifically set up to allow traps from the new device, or does it catch everything sent to it?
jreekers Thu, 05/10/2007 - 12:51
  • Cisco Employee,
If you're talking about the Ciscoworks server....
When you add the device to the network, two things can happen...
1. If Ciscoworks is configured to discover the network through the CM application, the new device will be automatically discovered.
or
2. The device will can be manually added into Ciscoworks via the RME application, and then syncronized to DFM.
You still should point the traps to the LMS server through the config on the device (as mentioned earlier).
Now if you're not talking about Ciscoworks, but some generic NMS, you will definitely have to have a trap receiver on the server, and still on the device have the "snmp-server host" command set to point the traps there.
Hope this helps,
-Joe
