message with show conn in pix
Thanks.
Following is message from syslog:
2007-05-10 21:43:55 UTC Local0.Info 192.168.252.1 May 10 2007 14:42:18 : %PIX-6-302014: Teardown TCP connection -1810930958 for outside:62.37.236.x/25 to inside:x.x.x.x/24856 duration 0:10:32 bytes 4294967280 TCP Reset-O
It looks finish send, but sometime show up again in the log file.
Ben
vitripat Fri, 05/11/2007 - 02:58
  • Gold, 750 points or more
It seems as pointed out earlier that a inside host x.x.x.x did send a mail 4GB or more, however the connection was not a normal finish, it was torn down becuse the mail server on the outside RESET the connection. Notice the flags in the syslog-
TCP Reset-O
Vibhor.
