hardware?
May 10th, 2007
We are looking to setup home offices that can have only 1 Ip Phone. We already have ASA5505 at site A they would work fine connecting back to the ASA5505 at site B but we are looking for the same sort of device but cheaper. As it will coonect to the existing ASA5505 on site B together w/ the ASA on site A.
Can anyone recommend?
thanks,
Robert
paolo bevilacqua Thu, 05/10/2007 - 17:07
  • Hall of Fame,
    Founding Member
Hi, you can look at the series 800 routers, there are various models depending the WAN connection and features wanted, see:
http://www.cisco.com/en/US/products/hw/routers/ps380/prod_models_comparison.html
The asa has the advantage of POE ports, the router (selected models) can be connected directly to the circuit, and can have embedded wireless.
If budget is the main concern, use the VPN client on the PC and IP communicator instead of a physical phone.
redrobish Thu, 05/10/2007 - 18:23
thanks. the 800 routers is a good one but our requirements is to put a physical Ip Phone at home.
is Linksys WRT54GP2 good? it is compatible w/ Ip phone? does it have POE?
thanks,
Robert
