MGCP ccm fallback
Answered Question
May 10th, 2007
Having an issue related to MGCP when phones are in SRST mode.
Phones register OK with SRST
Phones can call each other OK
No calls can be made in and out of the site via the E1
Under normal call manager mode it works fine.
Config is below:
ccm-manager fallback-mgcp
ccm-manager mgcp
ccm-manager music-on-hold
ccm-manager config server x.x.x.x
ccm-manager config
mgcp
mgcp call-agent xxxxxxxx 2427 service-type mgcp version 0.1
mgcp dtmf-relay voip codec all mode out-of-band
mgcp rtp unreachable timeout 1000 action notify
mgcp modem passthrough voip mode nse
mgcp package-capability rtp-package
no mgcp package-capability res-package
mgcp package-capability sst-package
no mgcp package-capability fxr-package
mgcp package-capability pre-package
no mgcp timer receive-rtcp
mgcp sdp simple
mgcp rtp payload-type g726r16 static
mgcp bind control source-interface Loopback0
mgcp bind media source-interface Loopback0
mgcp profile default
call-manager-fallback
secondary-dialtone 9
max-conferences 8 gain -6
transfer-system full-consult
timeouts interdigit 3
ip source-address x.x.x.x port 2000
max-ephones 96
max-dn 192
application default
keepalive 10
voicemail xxxx
time-format 24
Thanks in Advance to any suiggestions,
The answer is that it wont pull any info from callmanager.
The MGCP is master/slave relationship between gateway and CCM. Once lose connectivity between gateway and CCM, then MGCP will also lose the funtionality.
So you have add dial-peer for H.323.
You can just copy and paste the command below:
dial-peer voice 123 pots
incoming called-number .
direct-inward-dial
port 1/0:23 --> please change the port number T1/E1 PRI, BRI or FXO whatever you have
dial-peer voice 911 pots
destination-pattern 911
port 1/0:23
forward-digits 3
dial-peer voice 9911 pots
destination-pattern 9911
port 1/0:23
forward-digits 3
dial-peer voice 7 pots
destination-pattern 9[2-9]......
port 1/0:23
forward-digits 7
dial-peer voice 11 pots
destination-pattern 91[2-9]..[2-9]......
port 1/0:23
forward-digits 11
dial-peer voice 9011 pots
destination-pattern 9011T
port 1/0:23
prefix 011
Please rate the helpful post.
Ken
Overall Rating: 3.2 (6 ratings)
bartymil123 Thu, 05/10/2007 - 18:08
Thanks for the response Ken,
I thought MGCP takes care of all of the setup of these once the gateway loses its call manager connection, doesn't it pull the info from Call Manager?
Correct Answer
direct-inward-dial
port 1/0:23
forward-digits 3
port 1/0:23
forward-digits 3
port 1/0:23
forward-digits 7
port 1/0:23
forward-digits 11
port 1/0:23
prefix 011
Ken
bartymil123 Sat, 05/12/2007 - 15:03
I have added the following:
dial-peer voice 4 pots
destination-pattern 9T
port 0/0/0:15
dial-peer voice 1 pots
direct-inward-dial
port 0/0/0:15
If I now try and dial in to an extenstion will in srst mode I get:
beep beep beep, a few times then a message that the call can't be connected
Hi bartymil123,
Did you find a solution to your issue? I have a very similar issue that when my callmanager 4.13 is connected it works fine, but can not dial out when in SRST mode. I do get incoming calls however.
When I dial out in SRST mode, I get an error message to the effect of "I am sorry, the number your dialed can not be completed in your area.." voice ccapi and q931 debug show the call matched the dial-peer and sent out to the ISDN.
Here is the kicker, If I made the call to my cell phone from inside the router with the csim command, the call got out and rang my cellphone. The debug looks the same in both case.
I was on the phone with TAC but they had no clues yet.
It is very strange...
bartymil123 Sun, 07/01/2007 - 17:37
The problem was solved, we did not have any translation patterns configured to allow calls to go from extension to full number and visversa incoming and outgoing
It is working now with the addition of translation patterns and dial peers
sr2290723 Thu, 05/10/2007 - 21:26
I think you miss the dial-peer configuration. When fallback to SRST, the voice gateway will use H323 protocol. That means that you have to configure dial-peer to direct outgoing call. For example :
port 1/0:15
dgahm Thu, 05/10/2007 - 22:19
In addition to ccm-manager fallback-mgcp, be sure you have the call application alternate command.
http://www.cisco.com/en/US/products/sw/iosswrel/ps5207/products_configuration_guide_chapter09186a0080393a3c.html#wp1445728
MGCP Gateways and SRST
MGCP fallback is a different feature than SRST and, when configured as an individual feature, can be used by a PSTN gateway. To use SRST as your fallback mode on an MGCP gateway, SRST and MGCP fallback must both be configured on the same gateway. MGCP and SRST have had the capability to be configured on the same gateway since Cisco IOS Release 12.2(11)T.
To make outbound calls while in SRST mode on your MGCP gateway, two fallback commands must be configured on the MGCP gateway. These two commands allow SRST to assume control over the voice port and over call processing on the MGCP gateway. With Cisco IOS releases prior to 12.3(14)T, the two commands are the ccm-manager fallback-mgcp and call application alternate commands. With Cisco IOS releases after 12.3(14)T, the ccm-manager fallback-mgcp and service commands must be configured. A complete configuration for these commands is shown in the "Enabling SRST on an MGCP Gateway" section on page 34.
Note The commands listed above are ineffective unless both commands are configured. For instance, your configuration will not work if you only configure the ccm-manager fallback-mgcp command.
Please rate helpful posts.
Dave
