Catalyst 3550-24-PWR
Wondering if anyone has seen this behavior on this switch and if a resolution is available: Switch loses connectivity on 10/100 ethernet ports. Power is on but, all ports go black. This switches provides connectivity to Cisco Aironet 1200 Access Points. No other ethernet devices are connected to the 10/100 ethernet ports.
Amit Singh Thu, 05/10/2007 - 18:55
  • Cisco Employee,
What do you mean by that ports go black. the LED's dont blink. What are the symptoms of connectivity? do you loose connectivity...
What is the IOS running on 3550. Have you tried rebooting the box to see if that changes the scnario.
-amit singh
The 10/100 ports are normally flashing green. When I get a call the from the floor that they are unable to connect to access points the switch ports are no longer flashing green but, all lights are out. There is power and I can telnet to the switch. IOS VERSION: Version 12.1(13)EA1a. I've reloaded remotely but not cycled powered.
