royalblues Thu, 05/10/2007 - 23:02
  • Green, 3000 points or more
There are 3 ways to setup an RP
1. manual configuration in each leaf routers
2. auto-RP
3. bootstrap router with PIM version 2 (BSR)
First method the RP is defined staticaly on each router through the use of the command
ip pim rp-address
Auto-RP is used for dynamically distribute the RP information. All routers which are candidate RP's announce themselves to the mapping agent. The mapping agent is responsible for propogating this information to all routers.
When you have multiple RP's the RP with the highest address for the group wins
BSR can be used with PIM v2. It is similar to Auto-RP
have a look at this link
http://www.netcraftsmen.net/welcher/papers/multicast04.html
HTH, rate if it does
Narayan
devang_etcom Fri, 05/11/2007 - 04:58
  • Gold, 750 points or more
yes BSR its some what similar to auto AP... but Atuo-AP will elect the highest IP RP netry for various group... and advertise it... whereas BSR will advertise all AP...
Narayan few top topics in multicast is very logical right!!! need more and more reading and practice to understand...
regards
Devang
