procedure on how to modify the IVR scripts.
May 10th, 2007
Good Day All,
Anybody here can give me procedure on how to modify IVR scripts workflow?
Hoping for your future response.
Best Regards,
Lester
Chris Deren Fri, 05/11/2007 - 06:05
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
These should help you:
http://www.cisco.com/univercd/cc/td/doc/product/voice/sw_ap_to/apps_4_0/english/administ/index.htm
First you will need to install the CRS Script Editor from appadmin --> Tools, then follow the scripting guides to edit it, and save to repository.
Chris
