Multiple Port Forwarding @ PIX 6.3
May 11th, 2007
I know how to do it when it is only one port but when it is say 2000-2120 UDP of course I cannot enter 120 commands. How can I do that in PDM or CLI ? thanks
And I also want to know the syntax for the ASA...
vitripat Fri, 05/11/2007 - 02:47
  • Gold, 750 points or more
Unfortunately, there is still no way you can do port-redirection for a range of ports using a single command. Still we need to use a command for each single port, which means 120 commands in this case .. :-(
Vibhor.
