vpdn commands in 7.0 asa
May 11th, 2007
hows the going lads,
We are about to purchase a new ASA 5505 but it will be behind a netopia DSL router . The netopia will be put into bridge mode and the vpdn configuration will be applied to the ASA.
However I have read that the VPDN commands has been replaced in 7.0 so my question is how do I go about connecting back across PPPOE without the VPDN command .
Any help is really appreciated.
Thanks.
kcornally Fri, 05/11/2007 - 06:48
thanks Vibhor,
You're right it has been reintroduced thank god for that.
Kevin
joshua.walton@a... Sat, 05/12/2007 - 14:23
Note: PPPoE is not supported when failover is configured on the security appliance, or in multiple context or transparent mode. PPPoE is only supported in single, routed mode, without failover.
