Intern webserver
I have a cisco 827 and have make a static ip nat for intern webserver from the internet. This works great but if i want make a connection from my inside network to the webserver on the inside netwerk it doenst work.
- I have no intern DNS server
- Slit-horizon work only on PIX / ASA
- DNS Doctering work only on PIX / ASA
I there some solution with a commando how i can fix the problem?
bjornarsb Fri, 05/11/2007 - 01:02
  • Bronze, 100 points or more
From the inside you need to use the IP adr.
not the dns adr :)
HTH.
Bjornarsb
mohammedmahmoud Fri, 05/11/2007 - 01:06
  • Green, 3000 points or more
Since you have no internal DNS, you won't be able to access the server via URL, use its IP.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
mohammedmahmoud Fri, 05/11/2007 - 01:27
Yes you must have an internal DNS, to be able to access local servers via a URL rather than an IP.
Mohammed Mahmoud.
bjornarsb Fri, 05/11/2007 - 02:31
No,
Actually you can modify you host file on your computers, and if the computers are for instance hybrid nodes they will look in their hostfile first and your problem is solved.
However if you have many computers an internal DNS is best.
BR,
Bjornarsb
