Global IP communications problems with outside interface
May 11th, 2007
Hi all. I have small problem I need help to figure out
I have a Global statement:
global (outside) 2 1.1.1.10 netmask 255.255.255.240
And my nat statement is:
nat (dmz2) 2 0.0.0.0 0.0.0.0 0 0
Now, I have a host inside DMZ2 that wants to talk to my PIX's outside interface which is: 1.1.1.3
So the traffic goes from insidehost -> gets PAT/NAT with 1.1.1.10 (global interface) and then trying to contact the real outside interface 1.1.1.3. But it dont work
In my DMZ2 ACL i have the rule "permit ip any any" just to be on the safe side.
My insidehost can contact other sites outside my PIX. (I Have 2 other pix with other ip-ranges that the inside host can contact without problems.)
So, is it possible for the global interface to contact the outside interface or is that denied somehow intentionaly`?
Or do i need to add a rule in the outside ACL that permits the outside interface to communicate with the global interface?
Anders
vitripat Fri, 05/11/2007 - 02:41
  • Gold, 750 points or more
This wont work. But why exactly do you need a DMZ host to communicate with PIX's outside interface IP address? If you can tell the requirement like a webserver on inside using PIX's outside interface IP address, we may be able to help.
Vibhor.
It is recommended to use static nat translation for servers within a DMZ, for example.
static (dmz,outside) 66.44.44.33 192.168.1.1 netmask 255.255.255.255
If 192.168.1.1 (real address) is a webserver, then do:
access-l outside_in permit tcp any host 66.44.44.33 eq 80
access-group outside_in in interface OUTSIDE
