CISCO Catalyst 4510R
May 11th, 2007
Dear All;
i have CISCO Catalyst 4510R configured in my company. i just added WS-x4306-GB module. Fiber terminates in this modules. please help me how to monitor and check that module.
i will wait for your kind reply
soshomile Fri, 05/11/2007 - 03:22
Dear Amit;
Thank you very much for your kind reply;
i use "show module" it works fine. my another question is this;
how cuold we diagnose this module. using "sh module" command it shows that status that it exists. but is there any technique to check the connectivity issue, monitoring as well?
ankbhasi Fri, 05/11/2007 - 06:56
Hi Friend,
In general you can issue "sh logs" to find various messages and as per your requirement you can enable different logging levels.
Also see this link to check port status and connectivity
For enviromental monitoring
*Pls rate all helpfull post
