how to create a frame relay connection on an E1
bradlesliect
Using a 7206VXR router and I need to configure an Frame Relay connection on an E1. I need to use timeslot 25 on controller e1 1/0.
Can someone help me with commands to create interface as well subinterface?
Thanks a mill.
royalblues
Level 10
Level 10
Brad,
when you say you want to use timeslot 25, does it mean you want to configure a FR for just 64K
Here's a sample anyway for a Fr connection of 128K using timeslot 25 & 26
controller e1 1/0
channel-group 0 timeslots 25-26
interface serial 1/0:0
encapsulation frame-relay ietf
frame-relay lmi-type ansi
interface serial 1/0:0.1 point-to-point
ip address x.x.x.x y.y.y.y
frame-relay interface-dlci 100
HTH, rate if it does
Narayan
royalblues
Level 10
Level 10
Brad,
controller e1 1/0
Narayan
jsut for 64k
Royalblues has given you the example for two timeslots, showing you how the timeslots parameter works.
It would have been more appropriate to try from his indication and rate his posts, rather than ask again for a negligible configuration difference.
i will indeed rate his post. i was merely answering is question. Royalblues has ALWAYS been EXTREMELY helpful.
Royalblues - I THANK YOU MY GOOD MAN! :)
Bevilaquea - My apologies if i have offended you. I was in a rush when i responded to his post.
