VRF lite and shared service
Answered Question
May 11th, 2007
Hi to all, i'm triyng to use VRF-Lite with shared service.I tried to configure two different VRF (blue and red for example) and then i configured another vrf (for example server). I tried to export with route-target both vrf blue and green to vrf server and to import vrf server into vrf blue and green to give rechability, this is part of my configuration :
ip vrf green
rd 65001:100
route-target export 65001:100
route-target import 65001:100
route-target import 65001:300
ip vrf red
rd 65001:200
route-target export 65001:200
route-target import 65001:200
ip vrf server
rd 65001:300
route-target export 65001:300
but it doesn't work.
Any help appreciated
Max
p.s. is it possible to merge two vrf in VRF-Lite ?
Correct Answer by mohammedmahmoud about 9 years 11 months ago
I insist on my opinion :) and from your document:
Note This command is effective only if BGP is running.
http://www.cisco.com/en/US/docs/switches/lan/catalyst4500/12.2/31sga/configuration/guide/vrf.html#wp1045301
HTH,
Mohammed Mahmoud.
Overall Rating: 5 (1 ratings)
bjornarsb Fri, 05/11/2007 - 04:26
  • Bronze, 100 points or more
As posted in another group you need to
add a route-target export 65001:300
at vrf red and
a route-target export 65001:100
at vrf server
to give full reachability between the two VPNs
BR,
Bjornarsb
mohammedmahmoud Fri, 05/11/2007 - 05:10
  • Green, 3000 points or more
hi,
As far as i know, using route-targets is effective only if BGP is running. (route-target is an extended community)
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
rajju Fri, 05/11/2007 - 09:39
Hi:
That was very useful info on VRF-Lite.
Thank you very much.
Sincerely.
bjornarsb Fri, 05/11/2007 - 10:21
Hi mate,
You are very welcome!
Please rate if you find my posts helpfull.
BR,
Bjornarsb
Massimiliano Tognon Fri, 05/11/2007 - 23:35
I agree with you. I tested the configuration yesterday and VRF-Lite is able ONLY to make traffic isolation, and it seems not possible to merge two or more vrf together with route-target attributes.If you want to use this tecnique, you must run BGP (that is the try i had).I turned on BGP and MPLS and realized MPLS VPN.It's not necessary to have a neighboor bgp up to make Route-target work.
Configure BGP with vpn4 and vrf, and all works.If you want to merge more than one vrf with VRF-Lite, you have to make them in touch with a physical loop (for example with cross cable connected to both vrf) from one vrf to the other.Also Cisco eng told me to use a firewall to be possible to use shared service with VRF-Lite, configuring every VRF in one interface on the firewall and the shared service on DMZ.
mohammedmahmoud Sat, 05/12/2007 - 00:01
Very very nice, i've already tested it my self, i enabled MPLS and MBGP and it works fine. With just VRF-Lite, only traffic isolation can be done but no merge of VPNs can be done, its logical as VRF-Lite wasn't invented for this job, it was only invented for converting a CE router into multiple virtual routers each one with its separated routing table, interfaces and routing protocols.
BR,
Mohammed Mahmoud.
bjornarsb Sun, 05/13/2007 - 05:01
Yes , but you still have to
at vrf red and
at vrf server
BR,
Bjornarsb
mohammedmahmoud Sun, 05/13/2007 - 05:56
hi,
You are totally right, but the whole idea is that it can't be done with just VRF-Lite, you must have MBGP.
HTH,
Mohammed Mahmoud.
bjornarsb Sun, 05/13/2007 - 22:16
You can run vrf-lite with BGP.
As you have posted vrf-lite makes
you get separate routing instances.
Another cause why vrf-lite was developed
was that you do not need to run tag-switching between CE and PE.
So you can run BGP for each vrf.
Agree?
BR,
Bjornarsb
mohammedmahmoud Sun, 05/13/2007 - 23:17
Yes i totally agree :) VRF-Lite without MBGP (BGP with VPNv4) won't do it, but by having VRF-Lite with MBGP its doable. VRF-Lite alone is only capable of traffic isolation.
BR,
Mohammed Mahmoud.
richard.gu Sun, 05/13/2007 - 19:08
Why do you need to add those export route-tag?
In vrf red it exports 65001:200 and vrf server has import 65001:200. So vrf server should have all routes imported from vrf red. Same vrf red should have all routes from vrf server.
richard.gu Tue, 06/12/2007 - 12:47
I did a test in a dynamips environment. You don't need to an export to 65001:100 to allow import 65001:200.
The router just checks the route-tag in the MBGP route and grab the route that has route-tag match the import setting.
mohammedmahmoud Wed, 06/13/2007 - 03:04
Import and export under the same VRF are independent, in simple VPNs the best practice is that we import and export with the same RT (Route Target), while in complex VPNs we do import and export according the VPN design.
export RT --> attached to the routes when exported from the VRF (VPN identifier).
import RT --> Used to select which routes to be imported into the VRF from the routes received via MP-BGP (Import route filter)
Mohammed Mahmoud.
