VRF lite and shared service
May 11th, 2007
Hi to all, i'm triyng to use VRF-Lite with shared service.I tried to configure two different VRF (blue and red for example) and then i configured another vrf (for example server). I tried to export with route-target both vrf blue and green to vrf server and to import vrf server into vrf blue and green to give rechability, this is part of my configuration :
ip vrf green
rd 65001:100
route-target export 65001:100
route-target import 65001:100
route-target import 65001:300
ip vrf red
rd 65001:200
route-target export 65001:200
route-target import 65001:200
ip vrf server
rd 65001:300
route-target export 65001:300
but it doesn't work.
Any help appreciated
p.s. is it possible to merge two vrf in VRF-Lite ?
bjornarsb Fri, 05/11/2007 - 03:50
Keep in mind that can use:
Router(config-vrf)# route-target both 65001:100
mohammedmahmoud Fri, 05/11/2007 - 04:23
As far as i know, using route-targets is effective only if BGP is running. (route-target is an extended community)
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
bjornarsb Fri, 05/11/2007 - 04:51
Most routing protocols (BGP, OSPF, EIGRP, RIP and static routing) can be used between the CE and the PE. However, cisco recommend using external BGP (EBGP) for these reasons:
?BGP does not require multiple algorithms to communicate with multiple CEs.
?BGP is designed for passing routing information between systems run by different administrations.
?BGP makes it easy to pass attributes of the routes to the CE.
