05-11-2007 06:23 AM - edited 03-09-2019 05:58 PM
I'm about to purchase a C1841 router that will need to allow people with the Cisco VPN client (and perhaps a remote PIX at a later date) to connect to our LAN.
From what I've been able to find on the Cisco site the HSEC enables a hardware VPN module, while the SEC allows software VPN only. I don't imagine having more than a handful of simultaneous VPN connections, all but one of them being transient.
Am I right in thinking the SEC image will suffice? Are there any benefits to going with the costlier HSEC?
Thank you
Solved! Go to Solution.
05-14-2007 07:40 PM
Hi Paul
If you are sure that you are gonna have handful of vpn connections you can go ahead with SEC image itself but do keep in mind about the future may be after some point of time you may require more vpn connections.
so plan accordingly and move on with your configurations.
regds
05-14-2007 07:40 PM
Hi Paul
regds
