Power off router remotely
May 11th, 2007
Dear Friends,
I was wondering if there is any way/command to power off cisco routers/ switches remotely. Thanks!
- Manoj
sundar.palaniappan Fri, 05/11/2007 - 07:28
AFAIK the Cisco routers/switches do not support any command to power off remotely. However, you can use a third party UPS with an integrated terminal server to power off/on CPE remotely. Some high end switches may support the option of powering off the modules in a switch.
Danilo Dy Fri, 05/11/2007 - 07:31
Only command to power cycle them.
way and command has many meanings. There is another way which is to command someone in the remote site to power/switch off the router/switch. A little joke there :)
Manoj Wadhwa Fri, 05/11/2007 - 07:49
Hi Sundar,
Can you also plz let me know in some detail the 3rd party tools available to achieve this on a normal normal. Thx
hsrana2007 Mon, 05/14/2007 - 03:50
For this u need to insall smart Ip based Kvm switch at remote end.
so by accessing the powered KVM through ip , you can shout down the devices at remote end.
