VLANS
Answered Question
Im setting up a secondary core switch with a pair of 6513's and I have a problem.
Three of the 10 vlans I have created show up as down down and for the life of me I cant figure out why.
Im running Version 12.2(18)SXD7a on both switches.
Vlan1 172.16.255.254 YES NVRAM up up
Vlan3 172.19.240.254 YES NVRAM up up
Vlan4 unassigned YES NVRAM administratively down down
Vlan8 10.3.96.254 YES NVRAM down down
Vlan10 10.0.20.254 YES manual down down
Vlan30 172.16.30.254 YES NVRAM down down
Vlan109 unassigned YES unset administratively down down
Vlan160 172.16.0.254 YES NVRAM up up
Vlan610 172.16.10.254 YES NVRAM up up
Vlan611 172.16.11.254 YES NVRAM up up
Vlan612 172.16.12.254 YES NVRAM up up
interface Vlan1
ip address 172.16.255.254 255.255.255.0
standby 1 ip 172.16.255.1
standby 1 priority 110
standby 1 preempt
standby 1 authentication ****
interface Vlan3
ip address 172.19.240.254 255.255.255.0
standby 3 ip 172.19.240.1
standby 3 priority 110
standby 3 preempt
standby 3 authentication ****
interface Vlan8
ip address 10.3.96.254 255.255.252.0
standby 8 ip 10.3.96.10
standby 8 priority 110
standby 8 preempt
standby 8 authentication ****
interface Vlan10
description
ip address 10.0.20.254 255.255.252.0
ip helper-address 172.16.1.48
ip helper-address 172.16.1.50
standby 10 ip 10.0.20.10
standby 10 priority 110
standby 10 preempt
standby 10 authentication ****
interface Vlan30
ip address 172.16.30.254 255.255.255.0
standby 30 ip 172.16.30.1
standby 30 priority 110
standby 30 preempt
standby 30 authentication ****
interface Vlan160
description
ip address 172.16.0.254 255.255.248.0
standby 160 ip 172.16.0.1
standby 160 priority 110
standby 160 preempt
standby 160 authentication ****
interface Vlan610
description
ip address 172.16.10.254 255.255.255.0
standby 60 ip 172.16.10.1
standby 60 priority 110
standby 60 preempt
standby 60 authentication ****
standby 160 preempt
interface Vlan611
description
ip address 172.16.11.254 255.255.255.0
standby 111 ip 172.16.11.1
standby 111 priority 110
standby 111 preempt
standby 111 authentication ****
interface Vlan612
description
ip address 172.16.12.254 255.255.255.0
standby 112 ip 172.16.12.1
standby 112 priority 110
standby 112 preempt
standby 112 authentication ****
interface Vlan614
description
ip address 172.16.14.254 255.255.255.0
standby 114 ip 172.16.14.1
standby 114 priority 110
standby 114 preempt
standby 114 authentication ****
interface Vlan615
description
ip address 172.16.15.254 255.255.255.0
standby 115 ip 172.16.15.1
standby 115 priority 110
standby 115 preempt
standby 115 authentication ****
interface Vlan616
description
ip address 172.16.16.254 255.255.255.0
standby 116 ip 172.16.16.1
standby 116 priority 110
standby 116 preempt
standby 116 authentication ****
interface Vlan617
description
ip address 172.16.17.254 255.255.255.0
standby 117 ip 172.16.17.1
standby 117 priority 110
standby 117 preempt
standby 117 authentication ****
interface Vlan620
ip address 172.16.20.254 255.255.255.0
standby 120 ip 172.16.20.1
standby 120 priority 110
standby 120 preempt
standby 120 authentication ****
interface Vlan666
description
ip address 172.16.13.254 255.255.255.0
standby 66 ip 172.16.13.1
standby 66 priority 110
standby 66 preempt
standby 66 authentication ****
Correct Answer by ankbhasi about 10 years 2 months ago
Hi Friend,
Do you have any physical port assigned to vlan 8,10,30? Or do you have a trunk port configured which allow these vlans.
Any of the condition should be necessary to mae the interface vlan up and up.
Ankur
Overall Rating: 5 (1 ratings)
Correct Answer
ankbhasi Fri, 05/11/2007 - 08:00
  • Cisco Employee,
Hi Friend,
Ankur
ankbhasi Fri, 05/11/2007 - 08:18
  • Cisco Employee,
Hi Jim,
But then you must be having a trunk port configured which must be allowing those vlans.
Ankur
VLAN Name Status Ports
1 default active Gi4/1, Gi4/2, Gi4/3, Gi4/4
Gi4/5, Gi4/6, Gi7/1, Gi7/2
Gi9/1, Gi9/2, Gi9/3, Gi9/4
Gi9/5, Gi9/6, Gi9/7, Gi9/8
Gi9/9, Gi9/10, Gi9/11, Gi9/12
Gi9/13, Gi9/14, Gi9/15, Gi9/16
Gi9/17, Gi9/18, Gi9/19, Gi9/20
Gi9/21, Gi9/22, Gi9/23, Gi9/24
Gi9/25, Gi9/26, Gi9/27, Gi9/28
Gi9/29, Gi9/30, Gi9/31, Gi9/32
Gi9/33, Gi9/34, Gi9/35, Gi9/36
Gi9/37, Gi9/38, Gi9/39, Gi9/40
Gi9/41, Gi9/42, Gi9/43, Gi9/44
Gi9/45, Gi9/46, Gi9/47, Gi9/48
Gi10/2, Gi10/3, Gi10/4, Gi10/5
Gi10/6
3 VLAN0003 active
8 XXXXXXXXXX active
10 VLAN0010 active
30 VLAN0030 active
40 VLAN0040 active
100 VLAN0100 active
105 XXXXXXXXX active
120 VLAN0120 active
128 VLAN0128 active
129 VLAN0129 active
160 VLAN0160 active
206 XXXXXXXX active
251 XXXXXXXXXXXXX active
610 VLAN0610 active
611 VLAN00611 active
612 VLAN00612 active
614 VLAN0614 active
615 VLAN0615 active
616 XXXXXXXXX active
617 XXXXXX active
620 VLAN00620 active
666 VLAN0666 active
911 VLAN0911 active
999 XXXXXXXXXXXXXXX active
Jon Marshall Fri, 05/11/2007 - 09:12
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jim
Could you post the output of a "sh interface trunk" please.
Jon
Actually the output is empty since I have the two trunked interfaces down at the moment. You both might be right then.. I may have to bring those trunks UP to get the vlans to come up. It just suprised me that my other 6 vlans come up without being assigned to an interface yet.
I did make sure to use the trunkport vlan allow all command on both trunks g7/1, g7/2 to the primary 6513.
