Modem types
May 11th, 2007
Friends,
Can you please let me know what are the common modem types used these days for Leased lines, FR etc. Are there any good links that I can refer too. I want to understand the different signals and buttons available in a modem. Also how does the ISP test the link by using loops. Any good reference to understand loop ( hard, soft) will be highly appreciated. Thanks in advance.
Overall Rating: 5 (1 ratings)
Wilson Samuel Fri, 05/11/2007 - 09:57
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
Hi Manoj,
First of all these days its more common to have 'in built modems for T1/E1) like we get T1 CSU/DSU or MFTs hence the Router could be directly connected to the Telco cable (or drop out).
http://cisco.com/en/US/products/ps5855/products_data_sheet0900aecd8028d2db.html
http://cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a00801a9184.html
As far as the Loopback goes, generally I have used Hard Loopback in which we use either Loopback Jack (for T1/E1) or Loopback Barrel (for DS-3 Links)
Further information could be found at
http://www.cisco.com/warp/public/471/hard_loopback.html
Kind Regards,
Wilson Samuel
Please rate the post,
Manoj Wadhwa Fri, 05/11/2007 - 10:19
Dear Wilson,
Thanks for sharing your thoughts on this. Can you also give me some good reference to the modems used for links < T1/E1. Modem types such as mlln etc their functional and configuration/ testing. Thank you very much.
