2800 config with 4FXO VIC, voice-ports?
May 11th, 2007
I'm trying to configure the voice-ports on a 2800 router with a 4 port FXO VIC and when I issue the voice-port command it only shows ports 50-50 so I use
voice-port 50/0/1 and it comes back with invalid input at marker and it points to the 50.
boot system flash flash:c2800nm-ipvoice-mz.124-4.T.bin
boot system flash flash:c2800nm-spservicesk9-mz.123-8.T8.bin
Lights on the FXO card are lit up but I do not have any cables plugged into them, am I missing something?
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Fri, 05/11/2007 - 09:01
voice port 50 is for ephones that you may not have. Do you have PVDM2 in the router? Do show diag to know.
jmrosenfeld Fri, 05/11/2007 - 10:01
pvdm2, sorry I'm not sure what that is.
The show diag shows the VIC card is installed
I can configure the voice-card 0-2 but I don't see the voice-slots 0-4 when trying to configure those.
jmrosenfeld Fri, 05/11/2007 - 10:03
I'm guessing this is the info on the pvdm2?
WIC Slot 1:
2nd generation - FXO Voice daughter card (4 port)
Hardware Revision : 5.0
Top Assy. Part Number : 800-21589-01
Board Revision : E0
Deviation Number : 0-0
Fab Version : 04
PCB Serial Number : FOC092447VB
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Paolo Bevilacqua Fri, 05/11/2007 - 10:15
No, that is the voice card itself. To enable voice on ISR router you also need codecs in form of modules called PVDM2 that goes fitted in the router motherboard. Ask were you bought the router.
jmrosenfeld Fri, 05/11/2007 - 10:42
Ah I see; I have one router that shows them in teh show diag but the one in questions odes not. Is there any way to pop them out of one router and put them into another?
Paolo Bevilacqua Fri, 05/11/2007 - 11:28
Sure, it's a small module similar fitted in PVDM labeled slots on the mainboard. It is quite an easy job and if you look in the hardware documentation there are all the details.
As a courtesy to those providing answers, please rate all useful posts using the scrollbox below!
