CDR Service Activation
May 11th, 2007
Hi!
In the ?Service Activation? window the service ?Cisco CDR Insert? is active. When I enter the ?Server Parameters Configuration? window it does not appear.
I would like to configure the CDR Service parameters but this way it is impossible!
Chris Deren Fri, 05/11/2007 - 20:35
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
The CDR service parameters are found under CallManager Service, you need to enable the following service paramters:
CDREnabled
CallDiagnosticsEnabled
HTH,
Chris
