FXO port rollover
May 11th, 2007
We have a SIP trunk to a carrier. Yesterday, users were on the phone and experienced one-way out audio. This is related to the rxload being 255/255. We have 8 FXO ports for rollover. Is there a way to have the calls rollover to the FXO lines based on the rxload of the circuit?
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 05/11/2007 - 09:46
On the Gateway, there is. Not sure on CCM. What is your architecture, which protocol are you using to the GW ? you would need to trunk SIP to the GW and it can reroute calls depending on status of jitter probes, pings, etc.
mikepinto Fri, 05/11/2007 - 10:14
We are running a SIP trunk to the gateway. Is there anything specific to rxload of the interface? This seems like an IP SLA config. Am I correct? Thanks for your help.
Paolo Bevilacqua Fri, 05/11/2007 - 10:34
Actually, call fallback and related configuration. You cannot monitor directly traffic on interface, but you can define other paramenters to monitor.
As a courtesy to those providing answers, please rate useful posts using the scrollbox below!
