Upgrading WCS 4.0.81.0 to 4.0.87.0 ?????
Answered Question
I am trying to do an upgrade from 4.0.81.0 to 4.1.83.0 but release notes say to upgrade to 4.0.87.0 first, since users, etc. wont migrate. My question is: when I go through the install, it tells me I have WCS already installed. I say of and continue, it then says it's using port 80 and I should change this to go forward. Well, I am just trying to upgrade and not install another WCS on the server. Is there a process I am missing?
Correct Answer by ericgarnel about 10 years 2 weeks ago
Cool. Glad to be of help
Overall Rating: 5 (1 ratings)
ericgarnel Wed, 05/16/2007 - 05:29
  • Gold, 750 points or more
Stop the WCS service before you upgrade.
Are you doing on windows or Linux?
ericgarnel Wed, 05/16/2007 - 06:54
Have you rebooted the server?
Correct Answer
ericgarnel Wed, 05/16/2007 - 07:34
ericgarnel Wed, 05/16/2007 - 08:52
I believe under control panel| administrative tools | services, set it to disable.
I would leave it for now, there may be some shared dlls, etc..
I run WCS on linux and it is all contained under /opt/WCS4.xxxx
Plus the upgrade on linux is as follows:
backup, remove , install , restore. So, in essence, it is not really an upgrade, but installing a newer version and then importing the data
Trending Topics - Security & Network
