Subnet - Problem
May 11th, 2007
My Network 192.168.1.0 / 24
I want to allow 192.168.1.151...199 only 80 and 25,
how to do acl, wheather i need to create each host wise or can i use any range using subnets.. But i should not allow one host extra or less one host..exact 151..199.
can someone help to do with out host wise..
Overall Rating: 4 (1 ratings)
mohammedmahmoud Fri, 05/11/2007 - 14:00
  • Green, 3000 points or more
Use the following subnetting to cover your range:
192.168.1.151/32
192.168.1.152/29
192.168.1.160/28
192.168.1.176/28
192.168.1.192/29
HTH, please do rate if it does help,
Mohammed Mahmoud.
sundar.palaniappan Fri, 05/11/2007 - 14:21
Mohammed,
Your access list should work fine but can be shrunk by one more line like this.
192.168.1.151 0.0.0.0
192.168.1.152 0.0.0.7
192.168.1.160 0.0.0.31
192.168.1.192 0.0.0.7
Sundar
voiper_99 Mon, 05/14/2007 - 19:46
Interesting. Can I ask how you guys worked out the IPs & wild card masks that would be needed?
Wilson Samuel Tue, 05/15/2007 - 10:08
  • Gold, 750 points or more
  • Community Spotlight Award,
    Mobile User, July 2015
The best IP Subnetting, Supernetting/CIDR and VLSM page I have ever encountered is on a 3Com Website (Sorry, Cisco).
Please make a look into it and I'm sure you will never have to struggle with the IPv4 Addressing issues.
http://www.3com.com/other/pdfs/infra/corpinfo/en_US/501302.pdf.
Please rate if helpful,
Kind Regards,
Wilson Samuel
