webvpn & vista
Answered Question
May 11th, 2007
Does anyone knows Cisco has plan to support webvpn on windows Vista? Thanks.
Ed
Correct Answer by dominic.caron about 9 years 9 months ago
The webvpn (clientless) works(most of the time). The SSL client will work only with version 2.
Review this link
http://support.microsoft.com/kb/929490
Version 2 will only work on ASA.
Overall Rating: 5 (1 ratings)
fabiengermain Mon, 05/28/2007 - 07:08
I just asked the question to the TAC (for a 1811 router), and they answered :
"Actually, the SSL Webvpn AnyConnect client will only be available for the ASA platform (8.x). There are no plans on the roadmap currently to support IOS SSL VPN for Vista."
litouch Tue, 05/29/2007 - 10:49
Thank you.
Actually I have ASA5510 for webvpn. I also learned that Cisco would release ssl vpn client 2.0 in June, maybe together with ASA8.0.
Let's wait for that.
mikepent Tue, 05/29/2007 - 23:59
We use the SSL VPN with our VPN 3030 Concentrator. Does anyone know if the 2.0 client will be compatible with the Concentrators?
dominic.caron Wed, 05/30/2007 - 04:26
No, it wont be.(Checked with my Cisco SE)
I have 4 3030 that I have to migrate to ASA. It was a bad surprise for management :o)
The 3000 is at the end of the road. Dont expect any new feature to appear on that hardware.
