VPN 403 errors Vista using v5.0.00.0340-MSI
jrfollert
I used prf's from the XP 4.03 version (new vista install) and recieve the follwoing error on the Vista box when trying to connect:
Cisco Systems VPN Client Version 5.0.00.0340
Copyright (C) 1998-2006 Cisco Systems, Inc. All Rights Reserved.
Client Type(s): Windows, WinNT
Running on: 6.0.6000
17 15:53:10.938 05/11/07 Sev=Warning/2 CVPND/0xA3400015
Error with call to IpHlpApi.DLL: GetBestInterface failed, error 1231
18 15:53:10.938 05/11/07 Sev=Warning/2 IKE/0xE300009A
Failed to set up connection data
19 15:53:10.938 05/11/07 Sev=Warning/2 CVPND/0xA3400015
20 15:53:10.938 05/11/07 Sev=Warning/2 IKE/0xE300009A
PLEAS HELP
bwilmoth
Level 5
Level 5
Following steps may help you.
a) Go to start/run/msconfig/ Selective startup and take out startup items out, go to the tab "Services" and put a checkmark on the "hide all microsoft services" uncheck the options that came up. reboot and try again.
b)Try removing the client (without the startup items and services) and reinstall.
