Change the Route Administrative Distance ??
b.petronio
Level 3
Level 3
Hi all,
Is there any way of changing the Administrative Distance for a Directly Connected route?
I have tried this, but not working:
interface Ethernet0/0
ip address 10.9.1.100 255.255.255.0
interface FastEthernet0/0
ip address 172.20.254.254 255.255.0.0
ip route 172.20.0.0 255.255.0.0 10.9.1.1
ip route 172.20.0.0 255.255.0.0 FastEthernet0/0 200
TESTE#sh ip route 172.20.1.112
Routing entry for 172.20.0.0/16
Known via "connected", distance 0, metric 0 (connected, via interface)
Routing Descriptor Blocks:
* directly connected, via FastEthernet0/0
Route metric is 0, traffic share count is 1
Best regards,
Petr?nio
I don't think you can change the admin distance for a directly connected route. If your goal is to make f0/0 to be backup to e0/0 then you can configure something like this.
int e0/0
backup interface fastethernet0/0
Sundar
mohammedmahmoud
Level 11
Level 11
I don't think that it can be done, as there is no meaning for making a directly connected interface less preferred than a received route from another router.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
