how to use the established command on pix/asa
May 11th, 2007
hi all can someone pls tell me or guide me as to how to use the established command in pix or asa.
i know that this established command works differently than the established command in the ios routers.
here once a outbound connection has been made based on that connection i can make other connections permit in the inbound direction between same 2 hosts.
say if there is a proprietry application which uses dual channels
eg: when a outbound connection using tcp is made to dest port 8888 using any random source port.
the application will try to connect back to the source on a different port say 8080.this is against the rule of stateful inspection and so will not be allowed.
for such applications where the pix/asa cannot inspect we can use the established command to make it work.
i tried but i am not able to figure it out.
can someone pls help me.
hope to see a reply.
regards
sebastan
