HWIC-CABLE-D-2 in 2600 series routers.
May 11th, 2007
Hey all,
My first post here so thanks for having me.
Is their any way the HWIC-CABLE-D-2 can be compatible with 2600 series Cisco routers or if not, is there a DOCSIS WIC or NM that can be used in the 2600's?
I like the idea of having complete control over the entire WAN connection instead of using an external, unmanageable and unmonitored device for the RF interface.
Kris
scottmac Fri, 05/11/2007 - 19:59
  • Green, 3000 points or more
Welcome to the forums!
No, you cannot use an HWIC in a 2600 series router. HWICs are used in the x800 series ISR routers (1800, 2800,3800 ...).
You can use some/most WICs in an HWIC slot, but not the other way around.
Good Luck
Scott
