IOS-XR AAA Issue
May 11th, 2007
I will have to describe our infrastructure if I want to explain our
problem. In our network, we are running both Cisco IOS and Cisco IOS-XR.
Every device is configured for RADIUS authentication and authorization
(exec). This is the used configuration:
Cisco IOS:
--- cut ---
aaa new-model
aaa authentication login default radius local
aaa authorization exec default radius local
radius-server host <omitted output>
radius-server key <omitted output>
--- cut ---
Cisco IOS-XR:
--- cut ---
aaa authorization exec default group radius local
aaa authentication login default group radius local
--- cut ---
Now the problem description. It is enough to send attribute type 6
(Service-Type) with value 6 (Administrative) to login on Cisco-IOS and get
administrator privilege. But to get administrator privilege on Cisco IOS-XR
I have to send Cisco-AVPair = ?shell:tasks=#root-system? or some other
definition of task list.
And actually the problematic point is when I want to use single admin
account to log on both Cisco IOS and Cisco IOS-XR. IOS-XR can handle this
account configuration, but once I send that Cisco-AVPair to cisco IOS, I
got access-reject.
Attached the debug's file.
So I was trying to find solution for this (basically other method how to
log on IOS-XR and not send task list). I found this web page:
http://www.cisco.com/en/US/products/ps5845/products_configuration_guide_chapter09186a00806f9eb4.html
With this statement:
?AAA supports a mapping between privilege levels defined for the user in
the external TACACS+ server configuration file and local user groups.
Following TACACS+ authentication, the task map of the user group that has
been mapped from the privilege level returned from the external TACACS+
server is assigned to the user. For example, if a privilege level of 5 is
returned from the external TACACS server, AAA attempts to get the task map
of the local user group priv5. This mapping process is similar for other
privilege levels from 1 to 13. For privilege level 15, the root-system user
group is used; privilege level 14 maps to the user group owner-sdr. ?
I was trying to send priv-lvl to Cisco IOS-XR, but nothing like this
mapping happened.
So finally the questions:
? Is this priv-lvl mapping working only for TACACS+ and not
for RADIUS or is there any special configuration needed on Cisco
IOS-XR ?
? What will be your recommendation to solve this issue
(shared RADIUS server for both Cisco IOS and IOS-XR) ? Use of two
separate accounts (one for IOS and one for IOS-XR) is not an option
here, because we are using RSA tokens.
Any comments on that..
jeremyault Thu, 05/17/2007 - 13:12
In RADIUS protocol, authorization settings are passed to the device, at the time of authentication, in the form of attribute value pairs.
This is different from how TACACS works.
Essentially, what you want to do is to pass a vendor-specific attribute value pair to the router or switch at the time of login that specifies the user's privelege level.
The following example causes a user logging in from a network access server to have immediate access to EXEC commands.
cisco-avpair= "shell:priv-lvl=15"
How to Assign Privilege Levels with TACACS+ and RADIUS
http://www.cisco.com/en/US/tech/tk59/technologies_tech_note09186a008009465c.shtml
