View real user IP (nat)
May 12th, 2007
service C1
ip address XXX.XXX.29.130
active
content Test2
vip address XXX.XXX.29.143
protocol tcp
add service C1
active
group clients-group
add destination service C1
active
In XXX.XXX.29.130 not view user IP (only XXX.XXX.29.143)
How to transfer IP address user to a server XXX.XXX.29.130. For example through in header http or in url.
Overall Rating: 5 (1 ratings)
joquesada Mon, 05/14/2007 - 16:45
  • Bronze, 100 points or more
The CSS is not able to do add such header to the packet. While using 'add destination service' under the group configuration, you would need another device to add the required information to the packet, or fix the routing on your network to avoid the need to such command under the group configuration. Without the group, you would be able to see the client's IP on the server. Thanks!
Jose.
gnatvladimir Tue, 05/15/2007 - 02:14
1) What is another device for add required information to the packet?
2) if to update soft on CSS?
Gilles Dufour Tue, 05/15/2007 - 05:09
  • Cisco Employee,
the CSM and the ACE module are both Cisco loadbalancers that can insert info in the http header.
This feature does not exist in the CSS and there is currently no plan to add it.
Gilles.
