BSCI EIGRP Default Route
May 12th, 2007
On page 17 of the bsci quick reference PDF, it states that the following config will create a static default route and then include it in EIGRP:
ip route 0.0.0.0 0.0.0.0 10.1.1.2
router eigrp 7
network 0.0.0.0
My book states that eigrp will only pass a quad zero static default route if it uses an interface, not an ip address, in the ip route statement.
Which is correct?
Also on the same page, the "ip default-network 10.0.0.0" makes no note of the restrictions on using this method...ie that 10.0.0.0 must be included in the eigrp process "network 10.0.0.0"
I guess 10.0.0.0 could already be passed into the eigrp process by another router...
Am I out of my mind here?
CSCO10892433 Wed, 05/16/2007 - 02:11
  • Silver, 250 points or more
Hi, Paul
Do a lab test on your questions. Here is my conclusion:
1.A static route using a interface as the next-hop will be considerded directly connected.
2.A static route using an ip address (must be reachable) as the next-hop will be considerded a normal static route.
3.Network command under the eigrp process only has effect on directly connected routes.
4.A directly connected static routes will be advertised out if there is a network command incluldes this route, while a normal static route will not.
5. For those nomal static routes on which the network command has no effect, use redistribute static command instead.
6. Both 0.0.0.0/0 and default route defined by the "ip defalut-network" command apply to the same criteria. If they are directly conneted, use network command to advertise them out. If they are via a next-hop ip address, use redistribute static command instead.
SSLIN
