Can't Ping and telnet from PC to 2950 switch
Answered Question
May 12th, 2007
  • Silver, 250 points or more
Hi All,
I've created management vlan 100 in 2950 , 4000 and 6500 swithes.Connectivity is as below.
2950 ---6500---4000 ----PC .
And i've created few other vlans in 6500 and 4000 switches.I am able to telnet & ping to 2950 from PC which is connected to 4000 switch when my PC is kept in management vlan .Suppose if i configure my pc in different vlan IP i cann't ping or telnet to 2950 switch.managment vlan and native vlan in 2950 switch are different.
2950 switch config:
interface vlan 100
ip address x.x.x.x ---management vlan
int f0/0
switchport mode trunk
switchport trunk vlan 101 native allowed vlan 100.
6500 config:
interface vlan 100
ip address x.x.x.x --- management vlan
interface vlan 101
no ip address ---- native vlan
interface vlan 200
ip address x.x.x.x
interface vlan 300
ip address x.x.x.x
4000 config:
interface vlan 100
interface vlan 101
interface vlan 200
no ip address
interface vlan 300
no ip address
Satish
Correct Answer by sundar.palaniappan about 9 years 10 months ago
Satish,
There's no need to configure the 'management' keyword under the vlan interface. As you may know 2950 is strictly a layer 2 switch and you can have only one vlan interface configured and active on it at any given time. If the default native int vlan 1 was up then vlan 100 int wouldn't have come up at all. Given the fact you are able to ping the 2950 from your PC when the PC is on vlan 100 there's nothing wrong with int vlan 100 configuration on the 2950.
As you are able to ping the 2950 when the user is on vlan 100 but not from another vlan that indicates a potential problem with the PC or 2950 IP configuration as inter-vlan connectivity is what fails. Is the 2950 configured with a 'ip default-gateway' and was the PC configured correct gateway address for whatever vlan it was on.
Sundar
Overall Rating: 5 (1 ratings)
scottmac Sat, 05/12/2007 - 14:55
  • Green, 3000 points or more
I believe you have to declare the vlan as a management vlan (keyword is management I think)
For either of those devices, the native and the management VLAN can be different, so you must specifically declare both, or the management VLAN remains as VLAN 1.
Good Luck
Scott
smothuku Sat, 05/12/2007 - 15:13
Hi Scott ,
Thanks for your quick reply....To make vlan 100 as a management vlan on 2950 i need to specify management keywork under that particular interface.
int vlan 100
ip address x.x.x.x
management
I think if there is no "management " keywork under vlan 100 , vlan 1 would be the management vlan.Am i correct ?
I checked the same using the below link...
http://www.cisco.com/univercd/cc/td/doc/product/lan/c2900xl/29_35wc6/cli/clicmds.htm#xtocid53
I will check it and get back to you soon...
Satish
Correct Answer
sundar.palaniappan Sat, 05/12/2007 - 20:07
Satish,
Sundar
smothuku Sun, 05/13/2007 - 22:16
Hi Sundar ,
Thanks for your reply.
Actually the setup is as below.
2950 switch - 6500 switch --4000 switch---PC.
When the PC's ip is in mamanagement Vlan address range then am able to do telent to 2950 switch from PC.Few other vlans ae configured on 6500 and 4000 switches.If i configure my PC in different vlan then am not able to do telent to 2950 switch.
What could be the reason.
Satish
smothuku Tue, 05/15/2007 - 22:25
Hi Sundar ,
Thanks for your help...We configured IP default gateway on 2950 switch and able to access the switch from any vlan configured on 4500 switch...
I think default gateway must be configured on L2 for accessing it from different vlans.
satish
smothuku Tue, 05/15/2007 - 22:26
Hi Scott ,
Management keyword is not supported by 2950 switch...means whichever ios we are using may not support it..
But problem was resolved after configuring ip deafult gateway on 2950 switch.
Satish
thiyagarajang Sat, 05/12/2007 - 21:26
hi
I thik u have to configure Inter VLAN routing on 4000 and 6500 switches.
sathishs10 Sun, 05/13/2007 - 03:17
hi i think the management vlan is default vlan1 ,when u place ur pc in the in mangement vlan i.e vlan 1 then u'll b able to ping ,but if u change ur pc ip to some other vlan's ip address then u cant ping with out introducing layer3 device.
this is because vlan creates broadcast domains.
thanks
