inaccessible_boot_device error on CallManager Server
May 12th, 2007
I got the following error message on my CCM publisher server
" stop: 0x00000007B
inaccessible_boot_device, if this is the first time you hvae seen this stop error screen restart your computer, if this appear again followup these steps
Check for virus on your computer, remove an newly installed hard drives or hard drive controller, to make sure it is propably configured run chkdsk /f to check for hard drive corruption and then restart your computer"
Any one can help me to solve this problem ?
Mohamed
thisisshanky Sat, 05/12/2007 - 16:44
  • Purple, 4500 points or more
Mohammed,
Are you trying to install Callmanager and you are getting this error message ? This may be a problem with the SCSI drivers. I have seen this error if using the inappropriate hardware detection discs to install OS image on MCS servers. I am talking about 2000.2.x images and not 2000.4.x.
Sankar
PS: please remember to rate posts!
moabdallah Sat, 05/12/2007 - 19:17
I am not trying to to install
This CCM PUB server works for one year
CM version 4.1
Today, stop and give this error
Do you know how can i recover the server ?
Mohamed
neesharm Sun, 05/13/2007 - 02:30
  • Bronze, 100 points or more
Just wondering if you have tried chkdsk /f
moabdallah Sun, 05/13/2007 - 02:34
The server stoped
Windows is not loaded, and I can't excute any command !
Mohamed
neesharm Sun, 05/13/2007 - 02:46
I have seen similar issues when boot,ini file gets corrupted .....Do you have a BARS backup of the existing server ?
If yes you might want to try rebuilding the server.
Is it an IBM or HP server ?
Here is a list of possible reasons why it might happen
1. The system cannot access the boot device. Often, this message signifies a disk
controller configuration problem or an error in accessing the hard disk. This clearly
indicates that Windows has lost access to the system partition during startup.
2. Another possible cause is that, during initialization of the I/O system, the driver
for the boot device failed to initialize the boot device (device not available, SCSI
error).
3. Another possibility is that the file system could not recognize the data on the boot
device. The message also might mean that a virus has infected the boot sector
INACCESSIBLE_BOOT_DEVICE is almost invariably caused because Windows 2000 does not have an
appropriate driver available for the hard disc controller in your machine. It performs the
initial copy operation in DOS mode, but then it restarts and attempts to start up in
full-on Win2K mode, and without a driver it cannot find the boot disc--hence the error.
The solution is to find out what the hard disc controller in your PC actually is, download
a driver for it, put it on a floppy, and then press F6 near the beginning of Win2K setup
(when it asks you if you want to specify any additional hard disc controllers ) and
install the driver.
slopes Sun, 05/13/2007 - 04:39
Hi i faced the same prob with subscriber CCM,i did reboot few times and also make sure there is no hardware prob.i can't even go to safe mode.i use ERD commander 2005 and verify the boot.ini and just save the file and reboot the server after changes and u can see the subscriber is able to boot but only it run through chkdsk.
Problem resolved.
Rgds
Sanjeev
moabdallah Sun, 05/13/2007 - 09:45
What is the ERD commander 2005 ?
How can I verify that boot.ini is not corrupted ?
I can't get the command prompt
Mohamed
