NM-CUE have to be on same router as CME?
Answered Question
May 12th, 2007
Hi everyone. Does the NM-CUE need to be physically installed on the same router running CME 4? Or can these tasks be split among two different routers where one is running NM-CUE/Unity Express and another router running CME?
I have an existing 3640 router I could leave on the LAN. As far as I know this can handle the NM-CUE module. CME 4 won't run on the 3640 of course, but I would just use a 1760. If this isn't an option then I'm looking at a 2811 to run CME and CUE on the same box. This is for a fairly small job. I appreciate any further input.
Thanks!
Mark
Correct Answer by rob.huffman about 9 years 8 months ago
Hi Mark,
The good news is these can by installed on two separate chassis. The bad news is (as far as I can tell) the NM-CUE is not supported on the 3640. Have a look;
For implementations prior to Cisco CME 3.2 and Cisco Unity Express 2.0, these two components must be collocated in the same router chassis. As of Cisco CME 3.2 and Cisco Unity Express 2.0, this is no longer a requirement. While you should have LAN connectivity between Cisco CME and Cisco Unity Express (and not low-speed WAN links), these two components may now reside in physically different routers.
From this design doc;
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_implementation_design_guide_chapter09186a00804993bd.html
Cisco Unity Express voice-mail network module
NM-CUE
Supported on Cisco Routers
Cisco 2600XM series
Cisco 2691
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3700 series
From this doc;
http://www.cisco.com/en/US/products/hw/modules/ps2797/products_installation_guide_chapter09186a008007c8c4.html
Cisco 3800 series
Hope this helps! The ISR might be a good fit.
Rob
Overall Rating: 5 (1 ratings)
Correct Answer
rob.huffman Sun, 05/13/2007 - 05:37
Hi Mark,
NM-CUE
Cisco 2600XM series
Cisco 2691
Cisco 2811
Cisco 2821
Cisco 2851
Cisco 3700 series
From this doc;
Cisco 3800 series
Rob
MARK HOLLOWAY Sun, 05/13/2007 - 07:51
Rob,
Thank you for the information! I'm now thinking the 2811 is the best fit.
