Using a Policy Map to both prioritise traffic and DROP unwanted traffic
May 13th, 2007
Hi all,
Here's the problem. I want to drop all traffic except that defined in a policy-map. I'm using the policy map to serve two functions. Firstly to prioritize certain types of traffic and also to drop unwanted traffic by using NBAR.
Ok, here's an example. First the class maps:
class-map match-any platinum
match protocol rtp
class-map match-any gold
match protocol http
match protocol secure-http
match protocol dns
class-map match-any silver
match protocol smtp
match protocol pop3
match protocol secure-ftp
match protocol secure-pop3
class-map match-any bronze
match protocol ipsec
match protocol ftp
match protocol irc
class-map match-any drop
match any
and here's the policy map:
policy-map qos
class platinum
priority percent 20
set dscp ef
class gold
bandwidth remaining percent 30
set dscp 41
class silver
set dscp 31
class bronze
bandwidth remaining percent 10
set dscp 21
class drop
drop
I now apply it to my interface going out to the Internet:
interface dialer0
service-policy output qos
But, my problem is that as soon as it is applied, I can't surf the internet. However, as can be seen in the policy map, within the 'gold' class I have the following:
match protocol http
Furthermore, the 'gold' class comes before the 'drop' class. I've checked and every time I surf the internet, my web based packets are getting dropped by the 'drop' class. I don?t understand why this is!
To get around this, I have defined the following ACL:
access-list 150 permit tcp any any eq www
and added it to the 'gold' class.
match access-group 150
and it works, web traffic is detected by the ACL and output by the "Gold" service.
However, I?m not able to detect the web based traffic using NBAR (via the match protocol http command).
But the basic ACL worked. However, this is not ideal since it is vulnerable to programs like Skype masquerading as web traffic and tunneling out. Therefore, ideally I would like to capture the web traffic via NBAR using the 'match protocol http' command.
Does anyone know why this doesn?t work? or alternatively could suggest another best-practice method.
Any suggestions/help would be much appreciated.
Thanks.
- peter
Overall Rating: 3.8 (8 ratings)
mounir.mohamed Sun, 05/13/2007 - 08:37
  • Gold, 750 points or more
Dear,
First voice signaling is missing in the above classification rules, as soon as all NBAR classification matched on the class-maps (like DNS/POP3...etc) try to edit one of the avilable custome options using "ip nbar port-map protocol-name [tcp | udp] port-number " and test it if that work, try to update ur PDLM database.
Best Regards,
Mounir Mohamed
petermann Sun, 05/13/2007 - 10:11
Hi Mounir,
Thanks for you suggestion.
My pdlm I believe should be the latest since, I'm using IOS Version 12.4(13b).
As for the voice signaling, I forgot this but it shouldn't have affected the web based traffic.
I'll try using "ip nbar port-map protocol-name [tcp | udp] port-number".
I just find it strange that the router understands "eq www" in the ACL, but not "match protocol http" which from what 'I understand are the same!
Can anyone comment as to whether it is good practice to configure a 'drop' class in this way to save having to define an ingress ACL on the ethernet port.
oh and also may I ask you to clarify this point "as soon as all NBAR classification matched on the class-maps (like DNS/POP3...etc)". Apologies I dont understand this point.
Thanks very much for your suggestion.
- peter
petermann Sun, 05/13/2007 - 10:14
Further, I tried the suggestion. It didnt work:
BBR2(config)#ip nbar port-map custom-01 tcp 80
NBAR Error: Specified port(s) are associated with http
thanks.
mounir.mohamed Sun, 05/13/2007 - 11:52
Dear,
I mean does any class of the policy-map matchs "show policy-map interface x out"!!
Also regarding CEF issue, CEF supported and enabled by default since 12.2, also if CEF disbaled on your interface and you trying to enable policy-map it will return with error declearing that CEF must be enabled on this interface, you may use "show cef interfaces" to check if CEF is enabled or not, also check "show ip int x/x | inc IP CEF"
Waiting your feed back
Best Regards,
Mounir Mohamed
petermann Sun, 05/13/2007 - 13:48
here's the output:
BBR2#show ip int dialer 0 | inc IP CEF
IP CEF switching is enabled
IP CEF Feature Fast switching turbo vector
BBR2#
bjornarsb Sun, 05/13/2007 - 10:11
  • Bronze, 100 points or more
First I think you should do marking at your LAN interface and QOS on your WAN.
Second, have you verified that nbar is working properly:
sh ip nbar protocol-discovery
Bjornarsb
petermann Sun, 05/13/2007 - 10:16
NBAR appears to be working: Here's an output:
Dialer0
Input Output
Protocol Packet Count Packet Count
Byte Count Byte Count
5min Bit Rate (bps) 5min Bit Rate (bps)
5min Max Bit Rate (bps) 5min Max Bit Rate (bps)
http 1 34375
456 5196612
0 0
0 20000
It detects http, but drops it in the policy map with the drop class.
bjornarsb Sun, 05/13/2007 - 11:44
It could also be a bug.
"Classmap definitions based on NBAR match
protocol commands are violated"
For example,
match protocol snmp in
a Classmap definition could be come match protocol ssh.
BR,
Bjornarsb
mohammedmahmoud Sun, 05/13/2007 - 11:14
  • Green, 3000 points or more
Hi Peter,
Is any of the other match protocol other than match protocol http statement succeeding, can you please make sure that CEF is enabled, finally can you please do "sh ip cef summary", it might be a CEF problem with the dialer interface.
HTH,
Mohammed Mahmoud.
petermann Sun, 05/13/2007 - 11:47
Thanks Mohammed,
ok, as per your suggestions:
I cleared all my QOS configs then re-applied.
here's the 'gold' and 'drop' class. All counters are cleared:
I then run the command:
show policy-map interface dialer 0
Ive just included the relevant bits of the output:
Class-map: gold (match-any)
0 packets, 0 bytes
5 minute offered rate 0 bps, drop rate 0 bps
Match: protocol http
0 packets, 0 bytes
5 minute rate 0 bps
Match: protocol secure-http
0 packets, 0 bytes
5 minute rate 0 bps
Match: protocol dns
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 73
Bandwidth remaining 30 (%)Max Threshold 64 (packets)
(pkts matched/bytes matched) 0/0
(depth/total drops/no-buffer drops) 0/0/0
QoS Set
dscp 41
Packets marked 0
Class-map: drop (match-any)
0 packets, 0 bytes
Match: any
drop
I then try and surf the Internet and also access my email (via pop3).
here's the result of the command:
0 packets, 0 bytes
0 packets, 0 bytes
5 minute rate 0 bps
0 packets, 0 bytes
5 minute rate 0 bps
Match: protocol dns
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
QoS Set
dscp 41
Packets marked 0
Class-map: silver (match-any)
8 packets, 427 bytes
Match: protocol smtp
0 packets, 0 bytes
5 minute rate 0 bps
Match: protocol pop3
5 minute rate 0 bps
Match: protocol secure-ftp
0 packets, 0 bytes
5 minute rate 0 bps
Match: protocol secure-pop3
0 packets, 0 bytes
5 minute rate 0 bps
Queueing
Output Queue: Conversation 74
QoS Set
dscp 31
Packets marked 8
3 packets, 162 bytes
Match: any
drop
As can be seen, the "pop3" traffic is detected and output via the "silver" class, but the Internet traffic is dropped, and not sent out of the "gold" class via the:
match protocol http.
HELP!!!!
I've checked, and CEF is on. Here the result:
BBR2#show ip cef summary
IP CEF with switching (Table Version 125), flags=0x0
12 routes, 0 reresolve, 0 unresolved (0 old, 0 new), peak 0
12 leaves, 17 nodes, 19504 bytes, 97 inserts, 85 invalidations
0 load sharing elements, 0 bytes, 0 references
universal per-destination load sharing algorithm, id 28D228AF
3(0) CEF resets, 19 revisions of existing leaves
Resolution Timer: Exponential (currently 1s, peak 1s)
19 in-place/0 aborted modifications
refcounts: 4633 leaf, 4608 node
Table epoch: 0 (12 entries at this epoch)
Adjacency Table has 2 adjacencies
Any ideas anyone?
Thanks for the help so far.
- peter
mohammedmahmoud Sun, 05/13/2007 - 13:34
Hi Peter,
Ok, here is an idea, i have a past full of problems with NBAR :), implement the classification and marking on the input of the LAN interface, and then apply your queuing on the outgoing interface in a separate policy that matches upon your marking, and please do feed us back with the results.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
bjornarsb Sun, 05/13/2007 - 22:54
This won't help if nbar match is violated.
Have a look at this bug: CSCdr31111
Have you loaded a PDLM?
Anyway:
Create Classmaps and activate Protocol Discovery after loading
PDLMs.
BR,
Bjornarsb
mohammedmahmoud Sun, 05/13/2007 - 23:00
hi Peter,
I hope that you had time to test it in my suggested way, and please can you get the output "debug ip nbar unclassified-port-stats".
HTH,
Mohammed Mahmoud.
petermann Sun, 05/13/2007 - 23:47
Hi Mohammed,
ok, I put the original confuration on, (as per my first post), and ran the following command:
BBR2#debug ip nbar unclassified-port-stats
Port Statistics for unclassified packets are already being collected.
I activated "term mon".
Nothing is reported to screen when I try and access the internet using "HTTP".
Am I missing something?
thanks.
petermann Sun, 05/13/2007 - 23:30
Hi Mohammed,
That was very helpful thanks. As per you suggestion, I configured the following:
match protocol rtp
match protocol telnet
match protocol http
match protocol dns
match protocol smtp
match protocol pop3
match protocol ftp
match protocol irc
match any
policy-map classify_mark
class platinum
set dscp ef
class gold
set dscp 41
class silver
set dscp 31
class bronze
set dscp 21
class drop
set dscp 10
exit
interface fastethernet0
service-policy input classify_mark
end
Now when I do a "show policy-map inter fa0" I get "http" traffic being matched.
for example:
1792 packets, 280523 bytes
5 minute offered rate 13000 bps, drop rate 0 bps
1409 packets, 193834 bytes
5 minute rate 2000 bps
358 packets, 84753 bytes
5 minute rate 10000 bps
Match: protocol dns
25 packets, 1936 bytes
5 minute rate 0 bps
QoS Set
dscp 41
Packets marked 1792
So, the problem has been very much narrowed down. So I guess now the quesiton is why doesn't NBAR match the HTTP protocol on egress but does on ingress. Anyone got any ideas??
THANKYOU ALL VERY MUCH!
- pete
mohammedmahmoud Mon, 05/14/2007 - 00:07
You are welcomed :) thats the solution i did to work around it, and i am in the process of searching for a reason.
Mohammed Mahmoud.
petermann Mon, 05/14/2007 - 00:40
Hi Mohammed,
The thing is, whilst it works I don't really want 2 policy-maps on the router.
Whilst my first example illustrated marking the packets with a DSCP value, this was just for the example.
What I really want to do is us the policy-map as an advanced traffic filter, which gives me fine control (using NBAR) on what protocols are allowed on egress, and dropping the rest.
A simple ACL on the fa0 ingress (only working up to L4) would be vulnerable to programs like Skype and P2P which will tunnel out of other allowed ports (like 80).
The added advantage of course is that I can also priorities traffic with a policy map. - Two benefits for the price of one!
If you do find a solution, please let me know.
Thanks again. All the best.
bjornarsb Mon, 05/14/2007 - 00:51
What type of router is this?
You are in the situation that QOS features in the ingress direction is not supported in the egress direction.
So you should set ip precendence input and do
match ip precendence on output.
Bjornarsb
petermann Mon, 05/14/2007 - 01:06
Hi Bjornarsb,
I have tried this and classification of traffic on ingress works (even http), as illustrated in the previous post.
I realise best practice when applying QoS is to mark as close to source as possible, but in this scenario it is just a 1721 for a small office. I ideally do not want ?two? policy maps on a single router, one classifying and marking on ingress and other other applying scheduling on the egress.
I just want to drop traffic which doesn't match a "match protocol" statement using a policy-map applied to Egress. ? Essentially, a traffic filter using NBAR.
All the other protocols work, except "http".
All the very best.
- peter
bjornarsb Mon, 05/14/2007 - 01:18
OK, then I realy don't know. :)
By the way have you tried this:
hostname(config)# class-map http_traffic
hostname(config-cmap)# match port tcp eq 80
BR,
Bjornarsb
petermann Mon, 05/14/2007 - 01:42
hi Bjornarsb,
I very much apprciate your comments.
I will try what you have suggested this evening.
However, we are just matching on port, and therefore I suspect Skype and other P2P apps will take advantage and tunnel out.
thanks though.
pete
bjornarsb Mon, 05/14/2007 - 01:02
Or you could try just to do this, just call the class and do what you want without a new match.
ip cef
class-map match-any dscp46
match ip dscp 46
class-map match-all telnet_ping_snmp
class-map match-all http
match access-group 154
class-map match-all pop3_smtp
match access-group 153
policy-map voice_traffic
class dscp46
shape average 30000 10000
class telnet_ping_snmp
shape average 20000 15440
class pop3_smtp
class http
interface FastEthernet0/0
ip address 10.10.247.2 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/0.1
encapsulation dot1Q 1 native
ip address 10.1.1.1 255.255.255.0
service-policy output voice_traffic
Bjornarsb
petermann Mon, 05/14/2007 - 01:14
Thanks Bjornarsb,
But your example doesn't have a class drop. for example:
drop
class dscp46
class pop3_smtp
class http
class drop
drop
you would need this to capture the rogue traffic. From my experiences, when you have the drop class at the end, your http traffic will stop working, despite matching http traffic BEFORE the drop class in the policy-map.
thanks anyway.
