SIte-to-Site VPN problem
I'm having a problem with a site-to-site VPN. I'm attaching the basic diagram (public IP's excluded).
I'm trying to set up a lan-to-lan tunnel between the two pix firewalls, and the only way I can get communication goin between the two sites is if I initiate traffic from both sites at the same time (before the tunenl times out)...once that's done as long as I have traffic going accross it's fine, but if I stop sending traffic I have to recreate the tunnel by re-initiating traffic from both site. I'm guessing it's a problem with the edge routers...on the london side I'm getting this error (note this router is only supposed to forward traffic to the pix, no tunnel is supposed to be created on this router):
%CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has
invalid spi for
destaddr=*.*.*.*, prot=50, spi=0x354F6836(894396470), srcaddr=*.*.*.*
Here are the relevent configs:
London Router:
ip nat inside source static tcp 172.16.70.100 500 *.*.*.* 500 extendable
Europe Router:
ip nat inside source static udp 172.16.71.100 500 *.*.*.* 500 extendable
London PIX 6.3:
nat (inside) 0 access-list 101
access-list 101 permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
access-list london permit ip 192.168.70.0 255.255.255.0 192.168.71.0 255.255.255.0
sysopt connection permit-ipsec
crypto ipsec transform-set london esp-3des esp-md5-hmac
crypto ipsec security-association lifetime seconds 3600
crypto map hongkongvpn 5 ipsec-isakmp
crypto map hongkongvpn 5 match address hk
crypto map hongkongvpn 5 set peer ***public ip of europe router***
crypto map hongkongvpn 5 set transform-set london
crypto map hongkongvpn 5 set security-association lifetime seconds 28800 kilobytes 4608000
crypto map hongkongvpn interface outside
isakmp enable outside
isakmp key ******** address ***** netmask 255.255.255.255
isakmp identity address
isakmp policy 1 authentication pre-share
isakmp policy 1 encryption 3des
isakmp policy 1 hash md5
isakmp policy 1 group 2
isakmp policy 1 lifetime 86400
Europe PIX 7.0:
nat (inside) 0 access-list london-nat
access-list london-nat extended permit ip 192.168.71.0 255.255.255.0 192.168.70.0 255.255.255.0
access-list 101 extended permit ip 192.168.71.0 255.255.255.0 192.168.70.0 255.255.255.0
crypto ipsec transform-set RTS esp-3des esp-sha-hmac
crypto map RTS 1 set peer ******
crypto map RTS 1 set transform-set RTS
crypto map RTS 1 set security-association lifetime seconds 28800
crypto map vpntunnel 21 match address 101
crypto map vpntunnel 21 set peer ***public ip of london router****
crypto map vpntunnel 21 set transform-set london
crypto map vpntunnel 21 set security-association lifetime seconds 28800
crypto map vpntunnel interface outside
tunnel-group RTS type ipsec-l2l
tunnel-group ****** type ipsec-l2l
tunnel-group ****** ipsec-attributes
pre-shared-key *
tunnel-group ***** type ipsec-l2l
tunnel-group ***** ipsec-attributes
pre-shared-key *
Any help would be appreciated!
