Global policy question on ASA 5510
May 13th, 2007
Is it possible to have ip Inspect, IPS(with SSM) and QOS on the same global Policy and have them all work at the same time? It seems from what I have read I can have multiple matches to the global policy, however the ADSM doesn't seem to be able to set it up. I can do it from the command line but, just want to make sure that all three will work at the same time not just one of the three. Also, is there a best pratices guide for the ASA? Thanks for your help.
