GK cluster and port
May 13th, 2007
Does anybody know what the port the GUP packet use between two GKs when in a GK cluster?
ciscoforum Mon, 05/14/2007 - 10:50
My cluster is over the wan. So you think the port could be different from the link? I found a CCM tcp/udp port which mentions 11000-11999 for the H323/H245. I may use this range if no other document specifies the exact port or ranges.
Yes, i am doing an ACL to mark the GUP packets to CS3. Assuming this is what Cisco recommended to be same as all the call setup signal markings.
