Telnet of ASA firewall
May 13th, 2007
hi all,
After I added below command in ASA, the telnet session seeems success but there is just a cursor prompt without other configure i can see. any command i missed ?
interface Management 0/0
nameif management
telnet 192.168.1.0 255.255.255.0 telnet
nikolasgeyer Sun, 05/13/2007 - 21:42
  • Bronze, 100 points or more
Hi there,
The syntax for the command you are trying to use is as follows;
telnet
So for example, you have named your Management0/0 interface 'management' so the correct syntax you should use is
telnet 192.168.1.0 255.255.255.0 management
You currently have it assigned to an interface named 'telnet'.
Nik
acbenny Sun, 05/13/2007 - 22:31
Sorry, a typing mistake.
Currently, I have set "telnet 192.168.1.0 255.255.255.0 management".
When I telnet the ASA, a black prompt open but no words appear
nikolasgeyer Sun, 05/13/2007 - 22:42
Have you configured an IP address for the management interface? This needs to be part of a subnet and cannot be a /32.
acbenny Sun, 05/13/2007 - 22:55
Yes, already configured
int management 0/0
join_sn09 Mon, 05/14/2007 - 08:51
Dear Acbenny,
I met this problemed before, pleaes try to change other computer and one more your connection is slow.
Best Regards,
Join
