Access-list for block the DHCP request.
May 13th, 2007
Dear All,
How can I block a DHCP request on cisco 2950 switches, I tried given below access list but it was not working so plz suggest
interface FastEthernet0/4
no ip address
ip access-group 102 in
Extended IP access list 102
deny udp host 10.12.14.120 any eq bootpc
permit ip any any
IOS : Version 12.1(19)EA1c,
Thank you in anticipation,
Dipak
gmarogi Mon, 05/21/2007 - 06:05
  • Bronze, 100 points or more
The access-list which you have created is correct except the tu need to add one more statement to the list
access-list 102 deny udp any host 10.12.14.120 any eq 67
access-list 102 deny udp any host 10.12.14.120 any eq 68
Richard Burts Mon, 05/21/2007 - 06:09
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Gabriel
The syntax that you suggest may be better but it does not address the problem of trying to assign an IP access list to an interface that is not processing IP. I do not believe that you can do this filtering on a 2950 layer 2 switch.
Rick
luqmankondeth Mon, 05/21/2007 - 06:13
depending on the switch IOS, you can filter layer3/4 information on the 2950 on an interface that is not processing IP itself.
